Tv shuts on and off on its own. whenever it wants.
The first thing if you have not tried it is to unplug the set for a while and plug back in, this can allow the micro in the set to reset itself.
Failing that check for loose connection at power cord etc.
Failing that you may have a loose plug or solder connection in the set: suspect number one would be on the power supply board.
The problem is likely either a connection or a part in the power supply.
Have you had (this is common) problems where you have to turn set on several times to get it to come on?
