SOURCE: my john deere jx75 lawn mower won't start up.
There's a lot of safety features on tractors. Your owners manual would be the best place to check. I'll throw out a common spring time start up issue: dead battery. If you didn't have it on a trickle charger over the winter, tractor batteries die in 2 or 3 years. If it has started recently, check for a blown fuse.
For safety features, make sure you're sitting in the seat, brake on, clutch fully depressed, and any attachments (blades) disengaged.
SOURCE: I have a John Deere travelling sprinkler model
You can go to the following:
http://www.gilmour.com
There is an 800 number to call and you can also obtain a manual by selecting "Watering/hose end"
select "sprinklers" then "traveling". There you can download an Owners manual that has a parts breakdown in it
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
SOURCE: I have A John Deere traveling sprinkler that is
Sounds like the sealing rings for the arms have perrished and are jamming the arms as well as allowing the water to bypass.
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
