There are 2 rows of RCA connectors on the back of this TV. If you are looking at the back of the TV, on the right side you'll find the connectors. On the bottom row, left most RCA jack is the Video in for the Component video. on the top row, the right 2 connectors are for Audio connections. we put the Yellow plug from our Wii into the bottom row video connector, and the red and white RCA connectors into the top row plugs.
This enabled us to connect the Wii, and play games.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
I've this same issue, if someone's got a solution, please do share. :( I'm no noob when it comes to laptops but also not too much of a nerd either, i've ran the installation as administration and checked all the possible boxes and also changed the graphics. Still nothing.
You have either a pirated game or a game that was previously played on a hacked DS; this is an anti-piracy measure found in ROMs of the game or on cartridges that have been used in hacked devices. I had this exact thing happen to me as well. Wherever you bought it, you should return it immediately and get your money back.
Your signal board is bad and will need replacement. If you open up your tv and look at the signal board you can get a part number so that you can order one.
You can get get parts for this tv at www.interliquidparts.com
Call Sony. They will fix it for you, no problem. They will ship you a "Coffin" to send the PS3 back, and if it can not be fixed, they will replace it with a refurbished one.
If your Graphic Card does not support the 3D options, you won't be able any 3D PC games!
You have to look at your PC/Laptop specifications & the PC games requirements to play any higher graphic PC games. For any PC gaming PCs you have to install "DirectX' ie. latest version and updating graphic cards drivers too.
