On second ac adapter-universal. Faulty connection. Have to play with pin in port to maintain connection
Sounds like your Internal DC Power Jack is broken. It has to be repaired or eventually it will completely break and you won't be able to boot after the battery drains. It calls for taking your laptop apart since it is on the motherboard or sits in a slot on the motherboard. Most times it is soldered on the motherboard. You have to unsolder the old and solder a new on it it's place.
SOURCE: i need to turn built-in webcam on
use HP quick play to view web camera make sure you have the latest updates fr quick play to found at hp.com
thanks
erik
SOURCE: Cant connect usb mini adapter/ hid data stopped working error
Hi, My Name is Henry. I am one of the technicians here.
What windows are you using?
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
SOURCE: Activate (dv6)HP Pavilion bluetooth.
The Options tab in Bluetooth Devices provides options that control how devices discover and connect to your computer. The main option is Turn discovery on. This option lets devices discover your computer so that you can make a connection.
Other options on this tab include the following:
· Allow Bluetooth devices to connect to this computer
This check box controls whether any devices can connect to your computer. If this check box is cleared, no devices can connect to your computer.
· Alert me when a new Bluetooth device wants to connect
This option controls whether you receive notification when a device tries to connect to your computer. If this check box is cleared, you do not receive notification.
Other options on the Options tab let you turn on or turn off the Bluetooth icon in the notification area and restore default settings.
SOURCE: I have a HP Pavilion Entertainment PC. It worked
if needed you can reboot the computer tapping f8 when it comes up asking to start in safe mode click safe mode with networking and see how it acts and if needed goto start control panel programs and features and in the left column select installed updates and go down to the microsoft section find the service pack that was installed and delete it.
then afterwards restart the notebook and see how it responds back in regular windows after removing the service pack.
SOURCE: I cannot connect my HP Pavillion entertainment PC
First, make sure your wireless is turned on....The HP will have a switch to toggle the wireless on and off (it may be on the touch panel above the keyboard) Check your user manual to verify how to turn the wireless card on and off.
Then you may be able to use the HP wireless assistant to connect to it. If you don't like the HP Wireless assistant, you can switch it to use the Windows built in wireless utility, by disabling the HP Wireless assistant.
Take a look at this link: http://www.groovypost.com/howto/how-to/disable-the-hp-wireless-assistant-bloatware-microsoft-xp/ for some instructions on getting rid of the HP wireless assistant.
Good Luck
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
- Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
- Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
- Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.Figure : Charging with the universal desktop cradle
- AC adapter into electrical outlet
- AC adapter into universal desktop cradle
- HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
- Connect the HP iPAQ Pocket PC to an A/C power supply.
- Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
- Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
- Turn on the HP iPAQ Pocket PC.
