Hitachi HTS541612J9SA00 120 GB SATA Hard Drive Logo
Anonymous Posted on Mar 27, 2012
I have a Hitachi internal hard drive that i would like to use as an external hard drive to boot from my e-sata port, i have a Toshiba portege and i curently use two hard drives to boot from, one for work and one for personal, at the moment i'm swapping the hard drives round internally as and when i want to use them, but this is not ideal as i keep on having to take the laptop case off! I have an e-sata port on the laptop and i have got the e-sata cable, i removed the little plastic lip on the hard drive sata connection to allow the e-sata cable to fit bit it wont boot from the e-sata, i have set the boot order up to booot from e-sata 1st but it just goes straight to the internal hard drive! do i need a power supply to the external hard drive.. say from a usb port to the power connection on the HD? any help would be greately appreciated
  • Brian Sullivan
    Brian Sullivan Mar 28, 2012
    clarafication
    if the drive has a power input plug and is not a designated external usb drive
    you will need a power to the drive
Brian Sullivan
Level 3:
  • Hitachi Master 27,725 Answers
  • Posted on Mar 28, 2012
Brian Sullivan
Hitachi Master
Level 3:
Answers
27725
Questions
Helped
5664289
Points
79191
Yes you need power to the external hard drive whether ide or sata possibly depending on your hard drives power supply
12V+5V AC sata Adapter Power Supply HDD HARD DISK DRIVE
hope it helps
5 Related Answers
Anonymous
  • 111 Answers
  • Posted on Jun 15, 2007
SOURCE: HDD not recognised
HI Your Hard Drive is previously formatted and have done different partition provided by your previous machine where you took this hard drive from. Use "The Partition Magic" Software, it will help you to fix and repartition your hard drive in the new format. I have this problem before and now my hard drive can connect with any computer. The key in this issue is any hard drive goes with the original machine has been formatted and do its own partition from manufacturer so if you take it out later for use with other machine, you will need a software to completely rearrange the new partition in universal format so other computers can recognize it. This manufacturer purpose to protect your data from hacking, stealing once you take it out from the original machine. That is why when you connect it to other machine, this hard drive will not be recognized. I has this partition magic software and can make you a copy so you don't have to buy it. Just read the instruction and you can fix it for both 2.5" and 3.5" HD. Please email me at [email protected] and provide me your mailing address, I can send the copy software to you. Regards, pingping
ginko
Ginko
  • 19396 Answers
  • Posted on Apr 16, 2009
SOURCE: Computer doesn't recognize my external HD
Test the HD on a different computer, if you get same problem, then the disk can be faulty. Backup your data ASAP, then replace either exernal hard disk enclosure, or the hard disk drive, depending on what is faulty.
If you get no problem on other computers, then the system is causing the problem. In that case try doing a system restore to a recent date before the problem started. If that does not work, then you will have to reinstall the system.
steve_e_uk
steve morris
  • 1675 Answers
  • Posted on Mar 17, 2010
SOURCE: hi, my external hard drive recently cannot be
Hi there
I dont know if this will work for you but looking on the web I came accross someone who had a similar problem they fixed it as follows.
They installed Tweak UI and then
She was able to get the drive recognized using "Tweak UI", clicking on My Computer, Drives,and check marking Drive F. It did the trick.
Hope this helps software link for you
http://www.annoyances.org/exec/show/tweakui
Anonymous
  • 14 Answers
  • Posted on Apr 09, 2010
SOURCE: Hitachi 250GB external hard drive on Mac OSX problem
try to format it in other way like ntfs or fat32....
jdavies255
TechRx Inc http://techrxgb.com
  • 331 Answers
  • Posted on Sep 21, 2010
SOURCE: I am replacing a
You would need to use a "usb" to hard drive cable. It looks like this: http://gizmodo.com/168149/brando-sataeide-to-usb-20-cable
Then, it is simply a matter of "cloning." The other alternative is to find a pc repair shop with a hard drive duplicator. It will copy much faster.
Please rate if you find this helpful.
Testimonial: "very useful, though I'm still a bit at sea as to how one gets to the cloning software once the hard drive is a blank slate. "
Won' recognized my external hitachi z5k320
check data cable.
change use port and check the driver on any other PC.
if problem is same after doing so. check hard drive Cage. change driver Cage
2answers
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Laptop SATA drive not working
You cannot take a hard drive out of your faulty HP laptop and insert it into any laptop and expect it to run/boot up. When Windows is installed on a laptop, it is configured with device drivers for that particular laptop and it wont work in another laptop with different devices.
Replace the Dell's hard drive back into its laptop and the Dell should function normally.
To recover data off the SATA Hitachi hard drive, connect this hard drive into an USB hard drive adapter and then plug this adapter with the Hitachi hard drive into the USB port of your Dell. The Dell will detect the Hitachi as an external Mass storage device. You can then open the various folders and files to back up your data onto the Dell laptop or USB memory stick.
If you want to, you can use the Hitachi hard disk as an USB external hard drive by installing it into an USB SATA hard drive enclosure.
1helpful
Toshiba portege 3500 tablet saya tidak bisa booting lewat external cd room .. yang ada di layar monitor terbaca : intel(R) boot agent version 4.1.06 copy right (C) 1997-2002, intel...
It means that the BIOS cannot find a disk to boot.
Make sure you selected the hard drive in the boot settings of your BIOS
Remove all external DVD drives or floppy drives or ethernet cables
If you get an error message, you should start troubleshooting your hard drive.
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
2answers
How to install Windows XP onto a newly formatted laptop
put winxp cd in tray
at boot up press F12 - right-arroweto CD icon --> Enter
winxp should go into install
you'll probably need a version of winxp that can recognize Sata hdd. or hae sata drivers handy.
\system32\ntoskrnl.exe
I assume the pc does not boot to windows without this file.
You can reinstall windows. However, this will likely remove your data in the process.
If you can get into the BIOS, see if it can boot from the network or a USB drive. If so you can download something based on Linux that you can so boot and that is able to read/write to NTFS partitions.
The easiest way to replace this file for someone with little or no experience in these matters is to remove the hard drive from the tablet & hook it up to an IDE/SATA to USB adapter. Then plug it into a desktop.USB Port and it will be seen by the host PC as an add on hard drive.
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
