SOURCE: kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: washer won't unlock flashes f14.....Kenmore
F14 for Kenmore (Whirlpool) machines means EEPROM Error.
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU, if there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error. Check CCU. So its likely you'll need a new CCU board.
Check your owners manual, some models have up to a 5 year parts warranty on that CCU.
SOURCE: Kenmore Elite 110.22992101 won't achieve full spin
Hello the lack in spin speed is mainly due to a worn clutch which is shown on this diagram as part number 5 click this link for the schematic http://c.searspartsdirect.com/lis_png/PLDM/P0107049-00004.png here is also a video tutorial on how to change the clutch as well http://www.youtube.com/watch?v=tVc6SZ2DD4U you can also check this issue by when the unit is spining useing the palm of your hand against the inner drum if the drum slows or stops then it would definetly need a clutch replacement. If you have any further questions message me back the part number to order a new clutch would be 8299642 Thanks I await any further questions you may have.
Rick
SOURCE: kenmore side by side frig
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
