Estou limpando pois esta muito lento mas estou encontrando dificuldade para faze-lo
SOURCE: need to change cmos battery for toshiba laptop 1805-s274
look on back of laptop you will see some panels under panels you will see two little wires connected to mother board that's the cmos battery unplug it and change it
SOURCE: i required Toshiba Satellite 1805-S274 video
Found it...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=128927&rpn=PS183U&modelFilter=1805-S274&selCategory=3&selFamily=1073768663
SOURCE: I cannot boot from the cd rom to do a fresh
Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
Starting with the system powered off (not in sleep/suspend or
hibernate mode)-Start with the system powered off. Press the power
button and then immediately press and hold the Esc key while the system
runs the
POST (Power On Self Test). When the POST finishes, a prompt will appear
telling
you to press the F1 key to enter BIOS Setup. At that time, press the F1
key to
access the BIOS Setup program.
Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
