I used it on battery and when the battery was drained it turned of, later when it is on a c power it can be turned on but when the charger is removed it turns off, plus the battery is stuck on 73%
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
SOURCE: Battery Wont Charge
Hi there as per your information there is a chance of battery damaged. So i suggest you use your battery in others laotop for confirmation. If your found the same problem then buy a new battery . Thanks & waiting for your feedback.
SOURCE: My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
SOURCE: HP DV6915nr AC charger does not turn on or charge the battery.
You have a defective regulating circuit on the mother board that will not allow charging or a broken connector pin at power connection .
SOURCE: battery will not charge compaq presario v5000
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Testimonial: "good advice"
SOURCE: Samsung R40 laptop does not turn on.
You have a failing PMU on the motherboard it is like a sister bourd allowing the system to function nomatter what the situation this is fatal if not resolved i recommend a service center
Testimonial: "Thank you for this."
