Have Canon HS10 camcorder connected via usb cable. Imagemixer 3 captures audio / video and plays fine within that software. But if you load the file in Roxio Buzz, Picasa, Media Player, etc. get video but no audio.
Also I can transfer audio / video file from SD card in camcorder and load into the above programs and it works fine. Must be something the Imagemixer program is doing. Any ideas?
SOURCE: No sound when capturing video from Handycam to computer
There is no sound carrier on an S video connection. It's Video only. use the AV left and right cables for the sound. It is normal not to monitor audio when capturing.
SOURCE: Horizontal Streaks accross my lcd during record and playback
Are you trying to shoot from a TV or computer monitor? If so, check the frame rate--30frames per sec (fps) or 15fps. If it is on 30fps, changing to 15fps should solve the problem.
SOURCE: Canon hv30 is't being recognized on my vista computer
You may have used a different USB port on the computer. Try a different one.
Generally, any USB port would work, except that some devices create a "Virtual USB" connection that is configured with a specific USB port.
Let us know if this helped...
Gort007
SOURCE: I used the same SD card to create movie files with
Hello, the problem is that that movie you are copying back to the SD card to watch on your camera is not the right file format.
I've edited a whole video, but when I pulled the file to playback so I could burn it there wasn't any audio.
