Pro Power GOgroove FlexSMART X2 In-Car Stereo Bluetooth Adapter with Signal Intensifying Audio FM Transmit... (W15GGFLEXSMARTX2SRNPRTRI3GS) Logo
Anonymous Posted on Mar 26, 2012
It doesn't power up
It worked the first time I plugged it into my cigarette lighter jack, with the lights and everything. So I unplugged it, the second time I plugged the next day it did not power on. None of the power indicators lit up. So I am assuming that the product is not receiving power. I have checked my cigarette lighter and it is properly working. I have also tried plugging the device into another cigarette lighter jack/thing that I knew was working and it still didn't light/power on. I also tried looking at the fuse to see if I might have accidentally blown it, (I don't know how I would have done that since I only unplugged it once but you never know) with the correct fuse, and it still did not power on. What do you think might be the problem?
Shaun Shillady
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 29, 2017
Shaun Shillady
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
372
Points
There is a small power button at the base of the device. No offense, but are you sure this is still pushed in to the "on" position?
Also, I have the same device, but I did blow my fuse. However, I lost it and cannot remember the number on the fuse. Would you be willing to post the fuse replacement part number for me?
Rangerover sport 2006 56 Reg cigarette lighter doesn’t work
look in lighter hole if there is no clips on the side. this is phone jack not a lighter jack.
I bought a Nexxtech 175 watt inverter to power my laptop. It worked fine in my truck in the store parking lot but won't work in my tractor where I really need it. It works from the power point or the...
It could be any of a number of things, but the first 2 guesses I am going to make are:
1) The contacts in the cigarette lighter jack in the tractor are corroded; or
2) the wires that power the cigarette lighter jack in the tractor are too small of a gauge to provide enough current flow without a voltage drop. This one can be tested by popping the cigarette lighter jack out of the dashboard while still wired (carefully, you don't want to cause a short-circuit), and then plugging in the inverter and measuring the voltage with a multimeter going INTO the lighter jack. It should be at least 11.5, preferably 12, Volts. Test both before and after the inverter is plugged in. If the after reading drops too much, then you know you need a bigger gauge wire feeding the lighter jack.
'93 Jeep won't start - used cigarette lighter for gps instead of power socket
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Cigarette lighter in car
The lighter in a Chevy Lumina can get lost easily if you routinely pull it from the socket to plug in electronic devices like GPS systems, cell phone chargers and laptops. If so, you need to replace it.
1995 subaru cigarette lighter doesn't work
ok you are probably correct to think that you overloaded the plug and burned it out. I have seen decent replacement plugs at auto parts stores for about $10-15. Its a bit of a chore to remove some of the dash trim in that area but it can be done with some patients
1helpful
1995 explorer lighter doesn't work
I've seen the lighter itself burn out hundreds of times. Check for power at wire to lighter.
3answers
Cigarette lighter on 2004 Grand Prix isn't working.
The lighter socket or the element.
Check the element for burn marks and the socket for debris blocking the contacts.
Cigarette lighter ans accessour power point not working... it's not the fuse
I had a similar problem I thought it wasn't the fuse because I had only checked one but there are two cigarette fuses. Also you can replace the whole cigarette lighter if it is getting power to it. If it isn't there might be a bad wire leading to it. Get a test light to see if it's getting power through the fuses hole.
Top Pro Power Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pro Power Computer and Internet Expert? Answer questions, earn points and help others
