My Sony XBR 46 HX929 is about 5 months old. Last week it lost the video signal for several minutes and did not return untilI turned off the set for several minutes. Over the past two days the picture will dim and flicker for several minutes. Any ideas as to what is causing this ?
Customer care support SERVICE number+1--833'''272''''0777,,,,,,,,,,,call them
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
SOURCE: Sony Qualia and Sony XBR 4 TV
SOURCE: I have a Sony Bravia XBR 46
Please make sure that the connections are secure.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Please try connecting the TV to a different wall outlet and check if that helps.
SOURCE: FLICKERING PICTURE
Check power supply for the 24Volts connected to the backlight inverter ,bad caps could be the fault
SOURCE: we have an 18 month old sony bravia that for the
you have a bad panel (screen) call sony they may cover it .
SOURCE: Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
