Computers & Internet Logo
Posted on Mar 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have Belkin N600 (f9j1001v1) router + modem. Can I use it without modem. I have direct connection with LAN cabel, so i don't need modem. If it is possible to set ip,mask,gateway and DNS f
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 20, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
641
Points
0
I don't have an old modem........what should I do to configure my new belkin F9J1001v1 router+modem
Anonymous
Level 3:
  • Belkin Master 32,281 Answers
  • Posted on Mar 27, 2012
Anonymous
Belkin Master
Level 3:
Answers
32281
Questions
Helped
7907383
Points
102259
The Belkin router issues IP addresses to all your computer on your network.
You need to connect the Belkin to the the DSL or cable modem to allow your computers on your network to get Internet access.
If Internet access is not required then don't connect the modem.
2 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Nov 21, 2009
SOURCE: i have a belkin fsd7320 router and dlink 302 and cant get to net
It sound like youe wireless card in the laptop is not configured correctly.
The TCP/IP settings on the laptop's wireless card should be as follows :-
In the wireless card's Properties - TCP/IP
Enablw - Obtain an IP Address automatically
Enable - Obtain DNS server address automatically
This is the same for the LAN card.
Anonymous
  • 137 Answers
  • Posted on Mar 13, 2010
SOURCE: router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Without installtion cd and modemhow can isetup wireless belkin N150 modem-router model:F9J1001v1
There is an exact support article on Belkin site: How to set up the F7K and F9K routers without using the setup CD. Please, follow the http://www.belkin.com/us/support-article?articleNum=8117
You can find more info here: http://www.belkin.com/us/support-product?rnId=01t80000002wBTXAA2
I changed my Belkin Play N600 to strictly an access point, and now i cant access the settings again
Disconnect the router from the modem and switch off power to the router and after a couple of minutes restore power again.
The router's user name will have remained the same. If you have changed the router's password you need to press the reset to restore the factory default.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com
What network cable does a belkin N600 use RJ11or RJ12
Look again. Those "RJ11/RJ12" are not 2-pair/3-pair small Telco jacks but rather the 4-pair lager size found in Telco data com circuits (ancient DS0/T1 technology) and commonly now for Ethernet often referred as Local Area Network, LAN, data communications at 10 up to 1000 Mbps.
An RJ45 is larger and can not fit into an RJ11/RJ12 jack. The smaller RJ11/RJ11 will insert and make contact with the inner pins but if the line is active the Belkin device now has/will have a blown port. Don't!
Your Belkin N600 expects one Ethernet cable from a cable or DSL modem into the WAN or Internet port on the Belkin N600 for link through your carrier to Internet.
A four port gang of Ethernet RJ45 plugs is also present and is where your in-house PCs and Ethernet peripherals plug in. On the OEM website usually there is a colored quick setup guide to help you.
Some OEMs designate a yellow Ethernet wire from cable/DSL/satellite modem to WAN port and blue for internal LAN devices to try to reinforce outside verses after the NAT firewall inside the router for your internal LAN. The signal doesn't care about color it's for you.
The internally generated WiFi or WLAN (wireless LAN) is part of the LAN side but allows WiFi radio connection to client devices.
The 4-pair Ethernet cables have 8 conductors wIth the wire end of the plug to you and the contacts held upwards you will note the four pairs and their colors blue, orange, green and brown each with one conductor of the pair white with the color and then the color solid or more correctly the color with white stripe. Signals are on pins (left to right) 1&2, 3&6. On standard cable both ends are the same - a straight through, for hub to client. A cross-over cable takes 1&2 to 3 &6 on the opposite end and vice versa. This was for client to client or hub to hub connections before auto-sensing ports showed up to make the signals swap if needed automatically found in most equipment today. Some cables from OEMs have the correct physical size and pinouts, but only use the 2 signaling pairs. It is best to use these short distances and preferably away from rf noise like in modem to WAN port connections.
The twists per inch in the cable and interweave determines frequency response which defines CAT 3, CAT5, CAT5e and CAT6 level of Ethernet cables. CAT5 is fine else CAT5e/CAT6. CAT3 is generally considered now for telco use only, but can be pressed into into service short haul. (Won't get the 328 ft rated reliably above 10baseT speeds).
You may run across Ethernet with PoE this means on unused pairs a device like a video camera is fed power as well as data connectivity over its Ethernet connection. Follow directions to put power to the correct location as needed and look for any recommended grounding requirements, especially with antennas.
Prices vary widely depending upon bubble packaging and the store overhead generally $6-$12 for about 6 ft or 2 m.
If you want to make your own then RTFM and understand millage may vary until you get the right tools and parts and practice while adhering to standards. I find it more cost effective to use pre-made & tested cables except if failure at an end then I repair followed by testing to re-qualify the cable to not degrade its use.
OBTW - Generally the USB was for single computer use at lower speeds of earlier service speeds below 3-6 Mbps - usually don't.
Trying to network with cricket a600 and belkin n600
Your Cricket is a modem so you don't need to connect it to your router.Router are for DSL.
I am trying to set up belkin n600 but my internet connection is a usb from verizon how to do i connect?
Hi
Though Belkin play router has a USB port on it, it would not accept the input via that port there by you can not connected the USB connection from Verizon to the router. You need to switch from USB connection to Ethernet connection on the Verizon modem contacting verizon.
Modem light is blinking no internet light
hi, there are two ways to assit you on this issue.Either you can call belkin customer care which is a TOLL FREE no. on the product box and get assisted or else proceed with the following basic steps.
1. the product that you have is an obsolette.
2.Before troubleshooting the belkin product. Please connect your computer directly with the modem (without router)on the ethernet(lan) port and check for the solid lights on the modem after turning it on, after that check for internet connectivity, if you can go online, its fine else you need to contact your modem vendor and get fixed.
3. if u can go online, then connect your router isolated port to the modem amd your computer back to the router's lan port(port 1) and check for the solid internet,power,modem,lan lights on the router.
4. if all are solid lights , check you can go online else you can hold the reset button at the rear side of your router for 2 mins if you have a cable modem and then check for connectivity.
5. If you have a dsl connection , then better contact customer care, they assit you very well.
Trying to hook up belkin wireless router to cable modem and don't know how the hook-up should be
If you have your pc connected directly to your broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Then connect the same cable to your Belkin Routers Internet/WAN port. Then take the extra cable that came with the Belkin router and connect it to 1 of the 4 lan ports on the Belkin router. Then connect the other end to your PC in the LAN port.
After that, restart your PC and everything should be fine.
Thanks
I have bought a belkin wireless g router. my pc is virgin broadband i need to connect an aspire lap top. where do i plug in to make the router work
If you have your pc connected directly to your Virgin Broadband modem through the ETH/LAN port on your pc then disconnect it from that port on your PC.
Thanks
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
