(MOD: PLEB27T8CCB, SER: NF33817279) The ovens quit heating correctly. They cannot get up to temp both working at the same time. I can get one oven up to temp by putting it on broil first, then once hot setting it on bake at 350 and it will usually hold that temp. But not always. They usually can't get over 225. Is the control panel shot? I haven't pulled the oven off the wall yet but is this easily replaced?
SOURCE: oven heats up very slowly and does not get very hot
Check your power to the oven at the terminals where the power cord connects.Should be 220 volts. Also check the terminals of the bake element for loose connections or a burnt wire.
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
SOURCE: frigidaire wall oven will not heat up very fast
The clock control has a relay that turns on the element. It could be failed and would require a new clock control.
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
