Hi there!
I have a renault scenic (2208) and i cant use the integrated handsfree set of it, because when i got a call, on the car's sreen appears "headset" and can hear the caller, and the caller just hear silence....have anybody any idea how can I solve it?
Thanks from Spain!!
did you pair the iPhone with the car, using Bluetooth?
it sounds like the car is expecting you to connect a headset so that you can bet heard using the headset's microphone.
if you did pair the iPhone with the car using Bluetooth, then look into the car's menu to see how you can choose which device can be used while you speak... the iPhone or a headset.
good luck!
SOURCE: iTunes cant connect/recognise my iPhone 3G
Hi Try and plug your iphone to another pc and see if the same problem is still there, if no problem is form your pc, other wise you are having a problem whit your iphone i would advise to send your iphone to repair to www.E-Repairs.co.uk
SOURCE: Cannot hear any callers of imcoming calls from my iPhone 3G
Removed SIM card, sync iPhone with iTunes. Reinstalled SIM card and resynced again. Incoming calls can now be heard.
SOURCE: My iPhone 3g won't read my sim card or anybody
Used compressed air to blow out sim card slot. May need new sim card. Contact Apple Support or AT&T
SOURCE: My Jawbone headset will not pair with the iphone
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
