Part of my viking griddle keeps flaking. it's the part near the front. it's very strange. the rest of the griddle works fine. Any idea why this is happening and how to prevent it?
I have the same thing happening with my Viking griddle. I have nearly the whole top seasoned to a jet-black state - and it is stick free!! Now up near the front edge the coating/seasoning is chipping off. I've just been taking the loose chips off and not worrying about it too much, it maybe the size of a half dollar at this point. The front edge of the griddle is the hot spot on mine; and I've learned to adapt my cooking techniques. My guess is the hot spot on my griddle is responsible for the flaking...
SOURCE: I have a viking rangetop
Check the amperage draw to the igniter, if it is over 3amps and no gas, first off check the valve on the manifold behind then control panel if the valve is open then check the wiring to the thermal valve if it is connected then it would appear that the thermal valve is defective.
SOURCE: Viking Griddle thermostat issue
replace the hotplate ignitor. you may in the future have simmilar problems with the ovens or broiler, there are 4 ignitors in my unit I have replaced each at lease once. it seems to be a weak link in the design. If you need more information contact c2d6c2 at yahoo
SOURCE: Problem with Viking stove griddle knob shaft
Abalos, we will be happy to assist you with your parts for the Viking griddle knob.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
SOURCE: griddle makes backfire noise
I get the same sound but I found it is actually coming from my stainless steel backsplash, it seems like the heat makes it flex from time to time.
