Unlock using this master code : 6150662117
First Trick : For Master code calculation
http://www.nokialockcode.com/calculate.php and enter it to unlock. For IMEI *#06#
Second Trick :
1.press "unlock" button
2.then press "back"
3.then deep press unlock and then suddenly press *
4.that's all you unlocked the phone successfully.
NOTE: it will not work on all nokia phones so please check the nokia phones before practising the trick;but the trick can effectively work on most non java enabled nokia phones
Third Trick :
Remove Your Sim Card, Power The Phone On
Press # From The (Insert Sim) Screen
Enter codes WITHOUT spaces.
Press * 3 times fast for (p)
Press * 4 times fast for (w)
Press * 2 times fast for (+)
Verify code before pressing the last #
Fourth One:
The only way you can reset the security code is to take it to Nokia or some mobile store where they will reset it using a flash cable.
xdgs z
I`ve nokia1100, and i`ve forgot the security code, it had happened many times when i try to insert the new sim card , it can be accessed. Please help me to get security code for Nokia with seriai no.355698005616810.
