Hi to get sim unlock code visit theunlockarena.com here they ask you the network name to which your mobile is locked and the imei number of your mobile .finally they send you codes to unlock it.
samsung e250 also have mobile tracker security function are you used them........so cell will notify your desired no. when sim card will change in your cell ........ or contact service provider for tracing your cell by the emie no which is identify your cell........
hi.. u can increase the ringtone volume of ur mobile through sound settings...Just click the main menu and go for settings option..There will be several options available in that click sound and u can increase the ringtone to a maximum limit..
In order to have full view of ur video before start playing the video go for "more" option which is available on ur mobile screen and u can select full display...
Try the code below at your own risk. I will not be liable for any damage this may cause to your phone.
Type the following codes on standby menu
*#0206*8378#
after typing you will be presented to a Test Mode menu Select H/W Test Select Audio Settings Select IIS Normal (option 10) this is the normal volume for the phone. Scroll down to select Rx vol. then change level 14 to a higher value. Maximum is 30,000, i set mine at 5000 You can do the same for IIS Normal2 this is the volume for Music Player
