I have an ORION Model:FTDV2004B TV/VCR/DVD that the dog ate the remote on. I have tried a couple universal remotes, but the codes listed for Orion do not work. Does anyone know who else ORION gets components from so I can try their remote codes in the programming?
Orion has made Emerson,Sansui, Admiral, Memorex, RCA, Toshiba, Insignia, Akai and Zenith.
Try those codes. You can call Orion at 800 289 0980. I think the replacement remote for the FTDV2004B is less than $20.
Hello, Well I have a Phillips universal remote but but maybe they are the same. For the Orion TV try 105, 115, or 713. For The Pioneer DVD Try 042. If one or more does not work, Look for a "code Search" button. Turn on the device, then push and hold down the code search button until the red indicator stays on, then release the search button. Press and quickly release the desired mode button (TV, DVD, etc). The red indicator blinks off once. . If it is a tv or vcr use the channel up button until the channel changes. Press the power button on DVD and see if it is right Hope this helps.
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Any luck? None of the comcast universal codes work for mine either.
