Washing machine working fine conditioner being used but water always left in draw washing machine is cold fill only
This video will show you how to keep your soap draw clear
and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE
question.
And don't forget to like us on
facebook
SOURCE: Hotpoint Ultima WT965
You have a blockage in the dispenser , remove and take all bits out and thoroughly clean.
SOURCE: hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
SOURCE: Water leaking from Door and Draw from Hotpoint Aquarius Extra
is the pipe were the water gose in clear it is leakiing by the door cus the water flows down the machine and own from the door hope this helps.
SOURCE: dispenser draw filling with water, i have been
You have been ill advised, there is a filter that you can clean.
Remove rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove top cover., check the hose from dispenser to drum is not blocked with powder..
If the dispenser drawer still fills up, then it is possible that the condenser is blocked with fluff.
This a major job to put right, you would be well advised to call an engineer if this is the case.
Hope this helps.
Testimonial: "Thanku, thanku! Lost manual and couldnt find it online. Now I can get help to pull machine out of its dark and dingy hole and fix it! Thanks again xx"
SOURCE: THE FABRIC CONDITIONER COMPARTMENT ON MY BWM129
The conditioner works by sythening, to do this water is diverted to the conditioner compartment. Lift this out ond check hole is clear in the little conditioner pot. although this is comman on many machines
