The symptom that you describe can be form three part.
Firs:
This happen more offen is when the ram is damage. Change the ram and see what happen. Or if you have to slot of ram can remove one and than check the other. a see what hapen.
Second:
The graphic card chip.
This issue normally happen when the laptop is overheated. So if your are working with the laptop and it overheat it with turn off automatically but can be damage the graphic chip. In this case you can resolve this open the laptop and heat it with heat gun.
(this section you need to be carefully)
Third:
Laptop screen.
Need to check if the problem is with the cable that connect the screen of withe the screen itself. if you start the laptop and it look start normally and you listen the song of windows start it mean that the problem is with the screen.
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
when u start your computer appear any logo or something?
no just a blank screen nothing comes up, i switched it off a couple times and it came back on the other day the green lights on so i don't understand why its not coming on to the screen
problem with your monitor screen need to repari send to a specialist is very difficulty to change by yoursalf
