It seems as though the coffee and or filter get plugged slowing the flow of water through the basket forcing the water to continue to rise and then it overflows.
SOURCE: water not filtering quick enough, basket overflows
Make sure your sprayhead is the proper one (5 hole) and in good shape. Also make sure that the hole on your filter basket has not been partially closed. This can happen if you set it on the hot warmer. As a last resort, you can slightly enlarge the hole in your filter basket.
SOURCE: My Bunn coffee filter overflows
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
SOURCE: Filter basket overflows after cleaning Bunn VPR Coffee Maker
Make sure you are using BUNN brand cupcake filters, not the shorter-sided generic variety. Also, inquire with BUNN about an optional attachment for some models that will slow down the rate of water flow. Lastly, ensure that you are not over-filling the basket with grinds. There is an upper limit to how much a coffeemaker will hold, and some people try to compensate for weak coffee by adding too much.
