SOURCE: Cannot remove plastic upper exhaust fan grill for cleaning
Here are the steps to take:
1. Unplug it from the outlet.
2. Remove the two screws hidden in the slats of the grille.
3. Jiggle it up and out to remove the grille.
You can download your owner's manual here.
SOURCE: How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
SOURCE: Where are the screws located to remove the grille
How do I remove light bulb that is out on inside of microvave???????
SOURCE: having trouble removing front grill to install
Just installed a GE Spacemaker - my instructions tell me to remove screws and then slide grill to the left and then remove. Have you tried that?
SOURCE: GE JVM1660AB002 Microwave door handle
Thanks for choosing FixYa and welcome. You are correct. It has to come out. You should be able to use a knife or equivalent to pop off the inner panel to the microwave. It should just pop out and then you will be able to get the other screws.
