Start by Identifying what type of Card you need to buy. The Manual would be Extremely helpful in identifying What type of Video card slot you have. If that option is out you can look in the device manager and that should tell you what type.
There are many types For any modern Cards your Hoping for an AGP or PCIe Slot bare minimum you need a pci slot.
If you have a Vesa or ISA slot you'd be better off spending money on a new Motherboard & CPU
Once you know what type of card to buy PCI, AGP, or PCIe go out and look for the best card that fits your budget and that your PC meets its requirements
Most new Vid cards require a power supply connection or sometimes two or a special power supply adapter in addition to the available card slot PCIe comes in different speeds x1 x8 an x16 Make sure you have the right one that your card needs before buying. AGP likewise comes in 2 varieties AGP and AGP2 they have a different pin count on their edge connector so make sure what connector it has. PCI just about every semi modern PC has at least 2 PCI slots question is are the currently filled with other cards
Once you've purchased your card, you need to determine if you have an integrated video card.
This would be a video connection that is built into your motherboard.
If you do then you need to look up how to enter your BIOS to disable it (Usually pressing<Delete> or <F12> during boot up. Then go through and change the on board video card to disabled
press <F10> to save and exit
power down PC
Unplug power cord
Remove case cover and install new Video card
Replace case cover and plug back in
Boot up PC
Get Operating system up
insert the CD that came with the new card to install drivers and utilities (Another alternative is to go to the website for the GPU or card manufacturer and get the latest drivers) [ often times the drivers on the install disc are already outdated]
reboot ....... Congratulations your need Vid Card is install Now go play that game your dying to beat ;)
Hope this helps
Dave
