Drills Logo
Posted on Mar 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove chuck on porter-cable model 978 drill
Craig Becker
Level 2:
New Friend:
  • Expert 142 Answers
  • Posted on Mar 30, 2012
Craig Becker
Expert
Level 2:
New Friend:
Answers
142
Questions
Helped
75121
Points
180
Remove the left hand screw from the center of the chuck then lock a allen socket in the jaws and use an impact wrench to buzz it off right hand. If the jaws don't work then weld a nut to in and buzz it off with a regular socket.
How do I change the bit on my porter-cable 18v drill? Where/how do I line up the black dial with the silver dial to release the bit??
I just looked at some illustrations on ebay of Porter-cable 18 volt drills and they appear to be fairly standard cordless drill/drivers fitted with fairly standard keyless chucks that you get hold of with both hands and twist in opposite directions like you are giving it a Chinese burn. The part of the chuck nearest the bit twists anti-clockwise to loosen.
If you have an SDS drill for heavier duty jobs the chuck is semi-automatic in the drill bit just needs pushing into the chuck and clicks into place but the outer part of the chuck is pulled back in order to release the bit.
May 07, 2017 • Drills
Husband is out of town so how do you change the drill bit on the porter cable keyless chuck drill?
Switch drill to reverse, grab drill head tight, do not grab bit, pull trigger, chuck will open, switch to forward center new bit hold head tight pull trigger. Make sure bit stays in center, Let me know if this helps.
While using my newly purchased drill model PLC1800 the chuck became disconnected from the motor, of course I don,t have the receipt. Have you heard of this problem before.
there should be a allen head screw that holds the chuck to the drill shaft should be a easy fix put loc-tite on screw threads before reattaching screw and chuck and tighten up screw
How to remove a chuck on a porter cable 978 drill. Have take out lock screw and tried turning chuck counter clockwise with no luck.
go to the tip section and I put detailed instructions there, or under my profile it is there also. Let me know if still having problems
Porter cable 3/8 chuck model 621. need to replace and cant find it
if you are talking about the J621 3/8 Professional drill the chuck kit number is 692074 and it lists for 43.30. You can but that from Dewaltservicenet.com or if you need more assistance let me know.
How to change a keyless chuck with a drill stick in it ?
Grab the chuck with a pair of water pump pliers, and crank it in reverse. Hang on tight. Spray some wd 40 in the chuck before you get it spinning again.
I already did that and still cannot break the chuck lose
see my post in the tips and tricks section for chuck removal.
2answers
I cannot get the chuck off the drill on a 14.4
open the chuck all of the way, look down inside
you should see a screw down in there
it is REVERSE thread
lock the chuck in a vise and remove the screw
My chuck would not rotate,(Porter cable 14.4V Hamm drill) but the motor would turn as normal as I pressed the switch. There was a grinding noise as the motor turned which I first heard when I attempted to...
It sounds like you were between gears. When you are in neither low or high, you are sort of in neutral. Normally it isn't a big deal. It happens to me occasionally, and I do what you did. You should be OK.
Porter cable 884 cordless drill
Most chucks have a tolerance the cordless drills where designed for drill bits 1/8 and larger the 3/8 chucks are a little better with the smaller bits .Check your owners manual and see if they have a min requirement listed for the bit size
Top Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Drill Expert? Answer questions, earn points and help others
