GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Irene Theders Posted on Mar 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE Profile (#PSC23SGRB) side by side refrigerator that is about 7 years old. The light comes on when I open the door of the fridge and freezer but that is all. The whole thing is dead. Not cooling either fridge or freezer. No lights on panel for ice, or for control panel in the fridge. What can I do? Is it fixable?
Anonymous
Level 2:
Novelist:
  • Expert 97 Answers
  • Posted on Mar 24, 2012
Anonymous
Expert
Level 2:
Novelist:
Answers
97
Questions
Helped
67384
Points
282
The freezer switch/thermostat is almost certainly bad. If you are sure your turning it on, and nothing happens, it is very likely bad.
If you have a multimeter, you can check and be sure that your getting power to this switch...and then with it in the "ON" position, check for power through the switch.
If you do not own a multimeter, you may wind up saving money to go ahead and call a service man. Otherwise, just to replace a part that you cannot check is a roll of the dice.
1helpful
Refrigerator light does not work on ge profile
Check for voltage at the light receptacle, and then try to find the wire from the door switch. There should be a schematic on the back of the fridge. The switch can wear out after ten years.
What problems exist with GE model pscs5rgxafss
I have a GE Profile Side by Side Model PSCS5RGXAFSSThe lights work but it does not cool (or work) in the Fridge side or the Freezer side. The front door panel numbers illuminate but, will not control any setting. What's wrong? The unit is 4 years old.
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
1helpful
Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
3helpful
Warm temp
u have a defrost problem if u shut it down 4 or 5 hrs with doors open then turn back on itll work tii u have it fixed
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
Front dispenser On GE stainless side by side
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
5helpful
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Top Refrigerators Experts
vince
Johnny 1000
