My usb kingston flash drive just started indicating 0bytes after i tried to format it and all my data on it is lose.pls someone help me solve this problem
Dont worry, you can usb flash drive recovery software like asoftech data recovery to get back your files. You may refer to this step by step guide
how to recover files from USB drive
You may check out this video tutorial also
Not need to worry! You can <a rel='nofollow' href="http://www.remosoftware.com/recover-data-from-kingston-pen-drive">recover data from Kingston pen drive</a> very easily. I also suffered with the same problem. I found software for this problem. Needy one can <a rel='nofollow' href="http://www.remosoftware.com/download#rwin">download</a> from here.
Thanks
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
SOURCE: i can't format my 512MB kingston data traveler
Dude I just fixed mine running the SKYMEDI tool version SK6211BA_20080917 on my 8GB kingston datatraveler 100 is hard to get it but you will find it, you need to determine what version of the sw applies to your flash drive, check the SKYMEDI website www.skymedi.com.tw
SOURCE: write protected
kiick azz.. u might try copy files from cd that has write protection.. i still try 2 find the solution..
SOURCE: Kingston Data Traveler 2.0 64 GB USB - file system
2gb kingston pen drive showing capicity only 4 mb so pls provide the solution
SOURCE: how can I format an 8gb kingston data traveler
Try going into Control Panel/Admin tools/Computer Management then Disk Management. You will see a display of all drives connected. Right click the flash drive the Delete Partition, Now right click again and format. Hope it works Cheers from Scott
SOURCE: I have Data traveler 102
You will have to be the computer administrator to change
any values on a hard drive click start control panel user accounts you should see a box with the administrator and the
guest account if you have made one click on the administrator this may vary depending on which operating
system you have click start click to open on my computer you should see your
hard drive usually C: right click select properties there will be an array of
options select the security tab option then advanced make sure you have full
control in windows 7 click start control panel user accounts click on the
administrators account if you have made one or you will have to create one in
windows XP USB drives can be write-protected by modifying the
StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to
open the find dialogue box and type "usb device" or
"driverdesc" to open usb mass storage device or type "usb mass
storage device" in the search windows. And right click on it and delete.
This will set the policy value to 0. then insert your usb device. It will work
fine.
# Remember: do not delete any unknow files in the registry as this will make
some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Testimonial: "my usb is readable but write protected is of kingston 102 8gb please help me removing writeprotection"
