It appears the photos are stored on the internal memory in the camers and this us usually a small memory. You most likely need to insert a large SD memory card in your camera say 8 to 16Gb or more depending upon your requirements..
that is because all the photos that you click is directly to phone memory, first change the default storage to memory card(you must have recevied a memory card or mmc), then transfer the photos from phone memory to memory card. check your phone manual else just to the menu and check the storage option
Hello - You're camera has a little less than 10 MB of memory with sounds exactly right (2-3 photos) with a 12 megapixel camera. Such images are large.
You need to purchase a memory card to insert into your camera to store pictures. Your camera takes several kinds of memory cards but I suggest your purchase a SD memory card of two GB in size. You can get them almost anywhere, Super Markets, Chain Drug Stores, Places like Walmart, Kmart, etc.
It'll cost about $15 or so.
Happy Photo Snapping,
Mikeywaf
Check the setting where the pictures are being stored. It may be still storing to the internal memory.
Also check what resolution you are capturing your snaps. Although 22 pictures should not fill your memory but high resolution photos can take 5-6 MB /photo, so you can accomodate about 180-200 photos in 1GB. Try reducing the photo resolution, if you are not planning to print them.
Also, have you downloaded all the previous snaps from the card and deleted it from the 1GB card?
More than likely the camera still thinks the photos are on the stick, especially if you deleted the images while it was hooked to the computer. I would safely move the rest of the photos off the stick onto your computer then format the card through the camera and with the camera disconnected from the computer. this should clear the card.
It's very possible that your card has filled up with the 10 photos if they were taken in maximum resolution and in best quality. Check if there is anything else on the card such as videos. If you want to take more pictures, I would advise lowering the quality and resolution. Getting a bigger card would be also an option since they aren't that expensive nowadays.
There should be 2 settings, 1 for internal memory, 1 for external (card) memory. Internal memory is always low, especially if camera is set to high quality photos so only a few can be taken. check your settings on picture quality.
