This looks like the codes from a Blue Screen Of Death (BSOD). If so you will need a system disk to boot from and get to a dos command prompt (black screen with white writing) and type the following command:
chkdsk /r
Check Disk Repair will run for well over an hour and you will see the percentage of completion going from high to low but that is normal. Let it run to completion and then reboot.
In Windows XP to get to the dos command prompt boot from the system disk and when the options come up select Repair. Select 1 for the Windows Operating System and when it asks for the Administrator Password just press enter.
In Windows Vista to get to the dos command prompt boot from the system disk and when the options screen open you could try a startup repair. If it fails look the dos command at the bottom of the Recovery Console.
