Notifique mantenimiento
SOURCE: error message notify maintennce motor
Every time I have gotten this message, I have had to replace the motor controller.
SOURCE: notify maintenance motor controller comm
I own a gym and have 5 9500's...unfortunately it sounds like it the motor controller board which is around $800. National gym supply or sprotsmith has the part.
SOURCE: On display stands: MOTOR COMM BAD
Try Carolina Technical Services in South Carolina for all you East Coast guys. They charge flat rate of $175.00 and have a 90-day warranty. Also great turnaround time. Carolinatechnicalservice.com. 864-504-7303. Sure beats sending to California and having to wait for 3 weeks.
SOURCE: indicates motor controler comm bad
Check out www.carolinatechnicalservices.com. They can help if your boards look like either of the 2 on the website.
SOURCE: The screen says "motor control comm bad", what
Dear Sir:
Hello, i will help you, but unfortunately the factory use this software:
System usage statistics on main motor:
By that reason the problem is the Main Motor is faulty!, some technician from the factory must be set up your machine. You must call them for to replace the main motor, and adjusting in the main controller(Boar for control the main motor).
When you had been repair the motor , I will STRONG recommend you to install some stabilizer voltage in the power cord in the receptable is Not expensive, will be costo about us$15.00 aprox.
Thank you in advance, if you need some additional assistance, you can contact me, blessing, sincerely.
E. CUADRA
MANAGUA, NICARAGUA. C.A.
