Check the fan cover safety switch. If the latch holding the fan cover on does not fully engage the safety switch, the fan will not turn on. set the unit on the ground and see if it turns on. If so, the fan cover is too loose.Check the fan cover safety switch. If the latch holding the fan cover on does not fully engage the safety switch, the fan will not turn on. set the unit on the ground and see if it turns on. If so, the fan cover is too loose.
You can't post conmments that contain an email address.
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Don't add an extention cord to an extention cord! Buy a 100' 14/4 extension cord and tie the end to the fence so it won't come un plugged. If the plug keeps popping out of the short cord at the blower,wrap the cord around the handle to prevent disconnection.
Check the plastic tab that should engage the red safety interlock switche near the inside of the hinge. Both the tube and impeller cover should have them tall enough so they push the red contacts up all the way.
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit. You will have to purchase a new one. Sorry. Good Day.
all wires are connected
