Cooktops Logo
Carey Dietert Posted on Mar 23, 2012
How do I change the burner spark igniter on a PCS486GL Thermador Professional cooktop?
How do you remove the burner top to release the igniter? I have the replacement part, but not the special spanner wrench for the hold down nut
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 30, 2007
SOURCE: Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Anonymous
  • 530 Answers
  • Posted on Jan 18, 2009
SOURCE: Romvoing the top of my Whirlpool Cooktop
well usually you have to remove the knobs. thentake all of the caps off of the burners. sometimes there are scres that hold the burner caps on. make sure you turn the power off. Then after you have done this the glass should come right off. If not there may be screws under the cooktop. Do these first steps and let me know how it goes.
Anonymous
  • Posted on Jan 25, 2009
SOURCE: Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Anonymous
  • Posted on Mar 09, 2009
SOURCE: spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Anonymous
  • Posted on Jun 28, 2010
SOURCE: how do I remove the spark igniter when replacing a burner bowl
The spark ignitor is attached to the burner bowl by a retaining clip under the bowl. Simply remove the two screws on the top of the bowl, then you can slide the clip off from the underside
1helpful
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Ge monogram ZGU366LPSS one burner does not light up
It will light with a lighter just not the igniter which means the igniter is not working, sometimes they crack and run to earth, remove the top and turn off the lights you will see it sparking where it's running to earth.
Both extra low burners don't light
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Thermador cooktop won't light it has the ignite
try to clean a little bit the head of the sparkler and push the button for gas a little bit longer
1helpful
2answers
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
