Ertl 164 John Deere 4455 Tractor Logo
Posted on Mar 22, 2012
4455 John Deere Tractor
Our 4455 John Deere keeps over heating with only about 20 min of work. We have changed the thermistata and the cap but it hasn't made a differents. Any suggestions?
ryan bischer
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 08, 2013
ryan bischer
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
481
Points
Get the radiator boiled and cleaned., we had the same problem with our 4960 that we couldnt figure out why it was overheating we did that now never have no troubles
My John Deere lawn tractor keeps blowing the 20 amp fuse.
check and inspect wiring harness and components ----use multi meter to search for shorts
2answers
Firing order for my John Deere 3020 gas tractor?
Edited text with a wild guess at the maker. Make model (what it is) in all questions please.
Category moved to John Deere Tractor.
If it was working before, there is no need to worry about the firing order as that never changes. Things to look at;
Clean and correctly gapped spark plugs,
Clean gas,
Fuel filter?
and a clean carburetor, float bowl and jets.
John Deere 3020 Engine Engine Detail John Deere Firing order: Starter volts: Oil capacity: 9 qts 8.5 L 13 more rows •
Jul. 10, 2020
TractorData.com John Deere 3020 tractor engine information
John Deere 3020 Tractor Service Manual - Jensales
https://www.jensales.com > products > John-Deere-302...
This John Deere model 3020 Gas and Diesel Tractor Service Manual is a digitally enhanced reproduction of the original manufacturer-issued Shop Manual.
US$120.98 · ‎In stock
operators manual for john deere 3020 tractor owners ... - eBay
https://www.ebay.com > itm
3020 Tractor Operators Manual. This operators manual includes Gas, Diesel, Lp. This comprehensive manual includes. Fully Covers Serial No.
US$15.97 · ‎In stock
JOHN DEERE 3020 Gas and Diesel Tractor Service Manual
https://www.ebay.com > itm > JOHN-DEERE-3020-Gas...
This is a new reprint of John Deere Service Manual SM2041 for the John Deere 3000 Series Tractors shown above. It is dated June 1961. Includes 3010 & 3020.
Why would a mdl 1035 john deere tractor keep blowing the starter fuse
There is a distinct possibility that this tractor was originally equipped with a 6 volt system. If it has been upgraded to a 12 volt starter, the ignition will need to have a resistor installed to bring it back to 6 volts.
I could be all wrong on this but it's worth checking.
Electrical problem on a john deere 420 lawn tractor
remove the upper engine cover and inspect for a build up of grass and or a mouse nest that would over heat the coil and the engine
I have a John deere L-130 lawn tractor that creates a vacum in that gas tank. It stalla ater 20 min. of use. The cap has no vent. Is there another line/filter?
GY20473 gas tank from deere had a cap with a vent. GY21102 tank had a vent hose and was the later version. My guess is that you have the early version of the tank with the newest fuel cap. I recommend a new cap with a vent or drill a 1/32 hole in the top of the cap.
Problem solved
Thanks
Joe
www.arcolawn.com
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
3helpful
JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
15helpful
3answers
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 • Garden
Top Ertl Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you an Ertl Toy Expert? Answer questions, earn points and help others
