SOURCE: low battery
Your cam has a not so rare battery drain defect, mine had the same problem.
call Samsung and send yours in, they will either fix it or give you a new one.
SOURCE: displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
SOURCE: My samsung batteries keep dying. I just put new
Hello :
Try to clean the base where the batteries set . Maybe the base became rusty or got some isolation stuff on it . If that didn't help , then there must be a problem with the main PCB [ printed circuit board ] . For that you need to take your CAM to a repair shop .
good luck .
please don't forget to rate !
SOURCE: camera always says low battery even when you put
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
I should get a kennel - looks like you've been sold a pup
