I applied the all region hack and tried crazy settings and now can no longer get the all region hack to work so my question is how can I reset it to before I messed with it? I tried unplugging for a week but is that not long enough? I thought cutting power to it will refresh it, but maybe the capacitors are retaining some power or am I missing something? None of the factory resets work, nor the resetting directions in the manual.
SOURCE: insignia ns-pdvd8
Hey,
Try to use the same one as the newer version.
http://www.videohelp.com/dvdhacks/insignia-is-pdvd10/6028
1. Power on
2. Open disc tray
With remote control:
3. Press Setup
4. Select Preferences
5. Enter 253135
6. Press Left Arrow
7. Press Down Arrow
(you should be seeing "REGION CODE 1" now)
8. Press 10/0 to set REGION CODE to 0
9. Press Setup (and it's done!)
SOURCE: insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
Unlock
Insignia NS pdvd10
It`s really works
with all region)
SOURCE: Insignia DVD/VCR NS-DRVCR won't read dvds
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD lens cleaning CD.If still the problem persists, contact near by service center for replacing the faulty Lens.
SOURCE: Insignia NS-MVDS7/9 - unlock code
This information was found on the following website http://www.videohelp.com/dvdhacks/insignia-ns-7dpdvd/8394 It is dated as working on 01-08-08. I hope this information help you with your problem. 1.- Power on with no DVD inside the player; 2.- Press open on the DVD player; 3.- Press Menu button on DVD (or SETUP on remote control), (you see General Setup Page on the screen); 4.- Press the right key 3 times to select the Preference Page; 5.- On the remote control press 9653; 6.- Use the up and down key to select the Region, Select 0 for all regions; 7.- Press Enter. (This works with NS-7PDVD and NS-8PDVD)
I'm gonna try to solve my own problem by suggesting that I use this machine more often until it freezes like it does at times and hopefully when that happens and I unplug it, it'll reset the machine to factory settings.
