Toshiba Satellite Pro 6000 Notebook Logo
tooosh Posted on Mar 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ports/Interfaces on Toshiba Satellite Pro C660-171
Hi, i'm having troubles with ports on Toshiba Satellite Pro C660-171, the microphone-input is not functioning well since i bought it. the 2 x USB ports are not good as well... they keep disconnecting what is plugged in. Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
332
Points
7
Not a solution, NEEd HELP..
My usb ports have stopped working
Anything I plug in does not work.
Toshiba satalite pro c650
I looke at both usb root hub in device manager, the 'power' tab voltage reads 0
Any ideas please
Anonymous
Level 3:
  • Toshiba Master 6,771 Answers
  • Posted on Mar 22, 2012
Anonymous
Toshiba Master
Level 3:
Answers
6771
Questions
0
Helped
1777286
Points
21413
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Jan 29, 2007
SOURCE: Toshiba Satellite 5005-S504 3 USB Ports not functioning
I don't think a wire is the problem as they are soldered to mobo. It is more than likely a power problem. If you go to the hardware tab in device manager and go down to usb root hub>right click and properties then look at the power tab and you will see a 500MA allowance on usage. You can easily go above these if you are using them, so check that they are all active. Also go to control panel>admin tools>services and look down list for 'plug n play' and make sure it is set at automatic and 'universal plug and play' is set at manual
Anonymous
  • 49 Answers
  • Posted on Dec 14, 2007
SOURCE: Toshiba Satellite L10 that will not acknowledge a usb mouse or keyboard
use a different mouse or keyboard just to be sure. if it still doesnt work refer to the documentation
steve6375
Steve Si
  • 395 Answers
  • Posted on Aug 09, 2008
SOURCE: USB Ports Not Working
Check Device Manager for bad drivers
thehumble1
Daniel Herd
  • 137 Answers
  • Posted on Feb 26, 2009
SOURCE: Toshiba satellite pro u400 usb ports not working.
I would not start with new drivers. Try uninstalling the USB ports in the hard ware settings, then have the computer scan for new hardware, which should make it automatically find and reinstall the drivers for the device. Usually it will fix the problem if that is the extent of it. If that doesn't work, then get the drivers.
Anonymous
  • 43 Answers
  • Posted on Mar 20, 2009
SOURCE: Toshiba Satellite laptop with non-functioning USB ports
Try to search in Bios.
1helpful
What is the port number of the RJ12 connection on a Toshiba Satellite Pro laptop
You can find the port number by going into the control panel.
Find the device manager and look at the list of ports.
Your network adaptor may not be using a port, just memory to access it, in which case under the network device it will have a resource tab showing the memory location.
USB ports not working
jst see control panel usb setting or ur power scheme setings
How can i hook my toshiba satellite pro to my tv
there are some options here.. however they are limited to what ports are available on your computer AND on your tv.. for instance..
1 s-video, this is a round like ps/2 port thatt he computer and your tv have to have for video.
2 you can use a vga port from the laptop onto the tv for video
3 you can get a switch box that will be VGA from the laptop to VGA on the switch box that will use AV cables to the tv like a dvd player, and you'll just hook your computers headphone jack intot he jack on the converter box for sound through the tv.
4 buy a brand new smart tv.
1helpful
2answers
My two usb ports have moved towards inside of computer . i tried to disemble the computer without sucess. all srews battery, harddrive have been taken out. what else must i do to remove back cover
This issue requires intricate soldering, you need to send it to Toshiba for motherboard replacement. Most likely, the USB ports were pushed in too hard and the port broke off of its location. Even if you were able to access them, it is unlikely you could fix. However, this model is still fairly new, so send it to them and claim it came that way...
1helpful
2answers
The monitor is dead and there are no external vid
Buy a new screen and replace it, here is a service guide to help you in your endeavor. You can buy screens fairly inexpensively on Ebay stores that sell laptop parts.
http://tim.id.au/laptops/toshiba/satellite%20pro%20m10.pdf
Toshiba satellite pro 6100 usb not working
Try installing the usb driver or check if the usb ports is enable or disable if it is disabled plz enable it.To check this right click my computer click on properties,click on hardware devices,then click on usb to check it out.
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Usb ports on a toshiba satellite pro m15-S405
You can if you have good soldering skills. The welds are located on the opposite side of the motherboard. Just go to partstore.com or ebay to find a raw module to replace it. Otherwise you must replace the motherboard. Remember, heat the work not the solder, and use low watt if lots of smaller circuits are closeby.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
