Philips GOGEAR SA6045 MP3 Player Logo
Posted on Nov 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant get go gear 4gb player to play on my usb head deck >:(
Plug it in and it reads it sweet tells me what songs playing etc but stutters thru songs like its on 5 time fast foward or sumthin! help!
  • Drag250 Nov 06, 2008
    cuando encendi mi reproductor me decia q no habia ninguna cancion ni video q deporci no me acepta ni uno ni cuando lo tengo en su formato q pide, despues lo conecte a la computadora cuando vi no me leia las carpetas, es mas solo me aparecen dos carpetas pero no traen nada q debo hacer, en la computadora me dice formatear pero nose si quede igual q antes o como le hago por favor ayundeme.
  • st paddy Nov 25, 2008
    cheers dude, but ive got no problem gettin the mp3's onto the gogear, ive got a mp3 head deck in my car with a usb port, i plug it into the usb port and the name of the songs etc.. come up but it wont play properly, it stutters though songs like it on fast forward. my mate has a big version of the gogear and it works fine on my head deck.. any suggestions would be much appretiated.
    thanks
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Nov 25, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2173387
Points
14133
"File Format Not Supported" - SA6045/37
The file format not supported message means that the type of file you are trying to load into the GoGear is not compatible with the GoGear. There are no GoGear's that are compatible with iTunes. As far as WMA files are concerned, the GoGear's vary wildly. If the WMA file has a bit rate higher than 192 kbps (which is quite common nowadays), it will not work. If you actually have an SA6045, then make sure the license on the WMA file has "transfer rights," or that the license has not expired. You can check this by right-clicking on the song, selecting Properties, and looking at the tab that says "license" or "digital rights management."
If you find that you are using an incompatible format, convert the songs to mp3 format. If the songs came from CD, use Windows Media Player to re-rip the songs in Mp3 format. You can do this in Windows Media Player 11 by highlighting the "Rip" tab, pulling down the drop down-menu by clicking on the little tiny arrow that appears underneath the word "rip," and selecting "format", and then "mp3".
-Tha Mp3 Doctor
Sony TC-K690 3-head cassette deck with new belts & pinch roller tires doesn't play.
This decks need a feedback from different sensors and switches, if something doesn't check, it aborts right away.
Check if all the mechanical switches are indeed working, if the circuits that read that switch are working, etc.
5helpful
I cant listen to nothing but one song
Is the play mode (for this song) on REPEAT ? Are you able to select a different song ?
1helpful
Numark IDJ 2USB Flash Drive issues
use the lexar brand jump drive, they tend to work better the the dj station. i have a 64GB jump drive with 3,000 songs on it and it works great with no problems.
It will only hold about 20 songs (its 2gb) and will play on the computer but not thru the head phones (am I not switching it on properly?)
Plug your player into your computer with the USB lead,
Open MY COMPUTER and see the removable drive.
Right Click and select FORMAT
Note - this will delete everything on there but lets you start again and should hold many more songs
Hope this helps
I bought a 16 gb touch pmp from china and it will not play music
Hi
if you detele all the music from the player and then put in 1 or 2 songs, then play those two songs? do they play?
If they play fine, put in more songs, its very likely that you have been sold a face capasity player, I got a 16GB player from china, it was actually 4GB, everything above 4GB would not play.
read this page, and test your player with the program:
http://sosfakeflash.wordpress.com/2008/09/02/h2testw-14-gold-standard-in-detecting-usb-counterfeit-drives/
1helpful
3answers
Idj2 stutter start button
I have this same problem. I haven't found a solution anywhere, but a great workaround is using the Fader Start function - basically the moment the fader is slid into the main mix, the deck which you enable will start to play the tune. Hit the mode button, then select control, and turn on Fader start. It's actually really cool and allows you to do some ballsy mixes :) The deck will pause (or cue depending on the setting) once you bring it back.
Sync problems
try to use the utility that comes with ur device.
RADIO PROBLEM
you should be able to get a factory connector for the unit that matches the stereo to the vehicle internal wiring. you will have to go to the dealer for this but you should not have to get a new head unit. please rate this solution....thanks
Mp3 not playing thru phillips micro - mcm239d
Philips hifi systems only support flash memory sticks or MP3 players which show up as flash memory sticks.
SA5125 is not compatible
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
