Have a model SMH9151W Samsung Microwave Oven. The display screen says -SE- or -5E- and it will not operate. I unplugged it several time. It did operate once after that but an hour later it beeped 3 time and the se or 5E showed back up and it will not operate again
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
SOURCE: kenmore microwave model number 401.80084700 Displaying -SE-/-5E-
-SE- error means you
have a shorted membrane keypad.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and of course one should never leave a microwave unattended while cooking.
There are three ways you can get it fixed:
DE34-00178X SWITCH MEMBRANE $20.30
ref#53 membrane keypad
take yours off as in the video at
our site, peel the old keypad off as in this
handy guide with pictures
, clean the surface, stick on the new keypad
order by part number here
(We can do this job for you for a total of $70.25, but as you can see, the other two options are more practical and economical)
DE94-01647A ASY CONTROL PANEL $39.01
ref#66 control panel frame with keypad
our site, disconnect the keypad strip as shown
here, move your circuit board to the new frame, reinstall
DE94-01648A ASY CONTROL, BOX $58.12
ref#59 complete control panel assembly with frame, keypad and circuit board
our site, then install the new one
If these parts are not in stock, they should be available in about a week or so.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: Microwave model UMC5200BAB display is
"SE" error means you
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs
SOURCE: The microwave display shows "--SE--" I have not
SE error indicates a short in the keypad assembly. This will mean the the control panel or smart board will need to be replace.
Microwaves are not good do-it-yourself projects. Microwaves
are extremely dangerous to work on even while unplugged. Even
unplugged some components retain a lethal amount of voltage.
Here is a link for the website and contact technician: Sears Home Services .
Hope helps.
