When I load any disc "wrong disc" appears in the upper right hand corner of screen and disc will not play. Help please!!!!
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
How to change region
Have a norcent dvd player, states wrong disc, changed to region 255, same problem, any more suggestions please, thanks
I have tried every solution I know. Checked and changed zone codes to multizone code 255 with tray opened. Powered off player at player not remote, replace power tray closed disc loaded but still have the same error "wrong disc" are there any other solutions I can try??? Bonkers
Exactly as above
I put in the DVD
The lights blink as I see "Loading" in upper right hand corner (FOR QUITE A WHILE)
And then...that word goes away, replaced
by WRONG DISC
Same prob, although with unit open...the motor will not engage and spin up the dvd. Wthout the spin-up the unit will most likely state "wrong disk?"
