Toshiba 156 Satellite P755S5265 Intel Core i5 6GB Notebook 640GB Computer PC (PSAy1U00V005 Logo
Richard Smith Sr Posted on Mar 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I turn off wireless radio? - Toshiba 156 Satellite P755S5265 Intel Core i5 6GB Notebook 640GB Computer PC (PSAy1U00V005
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Mar 20, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1060635
Points
15385
There are a couple of ways to turn off the wireless. 1) Look for a wireless switch on either side of your laptop or at the front of your laptop. 2) Normally the FN (Function Key) + (F1 thru F8) will toggle the wireless between on and off. To find the correct F1 thru F8 key to hit look for the )))) symbol which denotes wireless. Press and hold the FN key then hit the Function key that corresponds to wireless. Watch your desktop screen because most will display Wireless On or Wireless Off as you hit the keys. If not one sure way to know it is off is look at the computer at the bottom right of the screen near the time, it should go from being a solid green to a computer with a red X on it.
Testimonial: "Thank you. I had already discovered that function after I made my post. I also found that I could go into the control panel and disable it. I failed to mention that it is running Windows 7. Thanks again."
How to turn on bluetooth radio
Which operating system ???...
There are a variety of ways to connect to the Internet or a home/business network using your Hewlett-Packard (HP) desktop computer---via a modem, Ethernet cable and even wirelessly.
A wireless connection works by sending a signal from your modem or router to your HP desktop's built-in wireless radio.
The radio receives and processes the signal so you can access the Internet or a home or business network.
In order for the signal to be received by your HP desktop, you must enable the wireless radio within the computer's configuration.
Click "Start," "Control Panel."
Double-click on the "HP Wireless Assistant" icon.
The HP Wireless Assistant dialog box will open.
Click the "Turn On" button next to the words "Wireless LAN."
Click "Close" to activate the wireless radio.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00045315&product=12455 - DeviceEnabled
Using Bluetooth Devices (Windows XP)
http://h20239.www2.hp.com/techcenter/wireless/wireless_TS.htm
Wireless networking center
IBM Thinkpad laptop Wireless connection not working laptop is asking to switch on wireless switch- "Where is it?"
Verify that the radio is enabled.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
  • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
  • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
I'm running Vista on my x31 2672 Thinkpad. I'm unable to turn on the wireless. I do not see a switch, what am I missing?
1helpful
Where is the wireless radio key on travelmate 2314 ? lost my wireless connection and they ask me to turn on my wireless radio to add back my wireless settings. thanks
Try going through your eNet Management to turn your wireless radio on.
Start>All Programs>Acer Empowering Technology>Acer eNet Mangement
Once in, you can your status and settings. Make any needed change and close program. The tool is easy to use and fairly straight forward. This should correct your problem.
Good Luck,
C2Solutions
1helpful
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Wireless radio turs off automatically
I have forgotton and need to reset the Bios password on a Tecra L2 S011 Labtop, can anyone help.
2helpful
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
1helpful
Wireless radio disabled
If you have a laptop and it has built in wireless adapter, it may have a switch or a button that you need to switch on in to turn on the wireless connection radio. Usually, it can be found on the sides or on the front panel of the laptop. On other laptops, you will need to hit some combination of keys on the laptop's keyboard to turn on the wireless connection radio, for example, Fn+F5. Please refer to the manual of your laptop for reference on how to turn on or enable its wireless radio.
By the way, what is the model of your laptop?
Wireless card
Go into the wireless configuration and see if the radio is enabled. The switch is for manually enabling and disabling the radio, if the radio has been disabled in the configuration then the switch will not work. The other thing you can do is, uninstall the wireless drivers from the device manager and reboot. The machine will find the wireless and reinstall the drivers. This should get it back up and running. NOTE- the radio is the terminology used for the wireless receiver, since the wireless card works on frequency it is considered a radio.
Wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
