I have error symble flashing on screen and camera will not record or replay. The manual says its a moistue issue. How to,fix it?
I've had this before. It usually occurs when go outdoors from an air conditioned space. Moisture condenses on the headwheel which will cause the tape to stick... and THAT will make a real mess!
If you're in a hurry, remove the tape cassette leaving the camera open, and use a hairdryer on LOW to dry out the inside of the unit. Then allow the camcorder to cool down (not in the cool or air-conditioned room) before you use it.
In the future, you should take the camera out of the cooled area still in the bag several hours before you intend to use it. To hurry things along a bit, you can put in a sealed plastic bag indoors and then bring it up to temperature, but don't open the bag until has reached the temperature of the space in which you will be using it.
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
