Atfirst i played the youtube video,it going fine after while i know buffering will happen atfirst before the video would smoothly play. After first video done,2nd done, 3rd done,then when i try to open 4th video...it takes long time...then i push play button twice times,then it start "shows device processor media busy",then "error playing"....then it never can play youtube video through using blackberry plan,if with wifi it smoothly can.every video takes 10 minutes.after this happened my data plan still have 230.45 mb, so why this black blackberry cant play the youtube video through browser using data plan?
SOURCE: how can I play youtube in my blackberry 8900?
Hi all,
This is because of the BlackBerry Browser as it doesnt support the Video Codecs (protocol).
If you would like to view video content from Youtube, you may have to download other Browser(s).
Another option is "Opera Mini". Which can be downloaded from this address:
http://mini.opera.com
on your blackberry browser: Press "goto" and then goto this address.
Select download and install the mini opera 4.2 application.
once up and running, you should be able to play video content on your blackberry.
(for the people who require to view the content on WIFI, they should go to the preferences of the opera mini browser and select the wifi checkbox).
Will appreciate if you can rate the offered support by me.
Best Regards,
Techno-geek.
SOURCE: When playing youtube I keep
ru2me2000 Hi first thing you need to do is take the battery out and let the phone reset next you need to be delete and reinstall the you tube application on your bb device. Second make sure you set all the permissions to allow on the you tube applications. You also may need to make sure that the applications is properly install on your phone. Also DO a reprogram of you phopne after you reinstall the appilcation of the phone.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
SOURCE: I try to play youtube
because when u r putting ur headset in blackberry then it show the media is error or ur aboflash is not required too play the video
SOURCE: y cant my blackberry curve 8520 cant play youtube
Welcome to Fixya.
If the problem is only with wifi and not 3G/EDGE.
On your BlackBerry, go to:
Options / WiFi connections / Select your Hotspot / WiFi Tools / WiFi diagnostics.
Check the local ip address
Example says 192.168.10.2**.
Login to your Wireless router, and find the DMZ option.
Add your BlackBerry's IP into the DMZ zone, enable and press save
Can you provide me with the make and model of your router so i can provide you on how to add DMZ on your router.
Thanks for using Fixya
