The Senco 700XL misfires a lot. It can misfire 3 to 10 times before it finally fires a **** nail. I need to fix it but I am not sure what to order to fix it. When I pull the trigger on a misfire I just hear some air simply come out. Don't know if it needs new "O-Rings" or what? I see them for sale cheap online, but might be hard to do? http://www.onlineorings.com/index.php?main_page=product_info&cPath=196_921&products_id=35053
The 700XL is a good gun worth repairing and fairly easy to work on. You should be looking for two Senco rebuild kits, part number YK0243 for the top end and YK0244 for the bottom end. After installing all the parts from these kits you'll have a brand new gun. To take it apart, remove the four screws holding the head cap on. Keep track of how everything comes out so you get back together the same way, the kits have good instructions to get all the right o-rings in the right places. The o-rings on the long skinny trigger valve are hard to get off and on but they will stretch enough to do so. Use the assembly lube liberally on all o-rings. The center piece in the cap can be pried out gently with a screwdriver and is hard to get back in but make sure it is fully seated and straight in the cap when you put it back together.
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
SOURCE: Paslode finish nailer. Pull trigger
Try the other order, where you depress the gun first, and then pull the trigger.
