No it won't.The brake switch is for brake light,interlock shift solenoids,transmission TCC controls,and stoping the vehicle, You fan blower has a completely different power supply that is independant from the brake electrical system, For you fan blower to operate its either the fan resistor blower or the fans control switch to the fuse
SOURCE: Blower for AC/Heater stopped working
if you can reach the blower motor, it could be a worn out carbon brush of the blower motor. if they are, buy a set of carbon brush, learn how to replace them and it would be back running in no time. by the way, when you pull out the carbon brush holder, make sure you dont interchange the position. you can put them back wards and what would happen is the rotation will be reversed. either you reversed the carbon brush holder or just simply interchange the wires that are coming to the motor. i hope i was able to help...
SOURCE: How to access ac blower and fan switch, 1999 Volkswagen Beetle?
if its work in only low speed u have to replace the blower motor resstor which located close to the blower
let me know have a good one
SOURCE: 1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
