Identify the headers: Locate the front panel headers on the new case and on the motherboard. Make sure that you have identified the correct headers and that they are compatible with each other.
Check the pinout: Refer to the manual for the new case to determine the pinout for the front panel headers. Make sure that it matches the pinout listed for the motherboard, as mentioned above.
Connect the wires: Use the pinout information to connect the wires from the new case to the appropriate pins on the motherboard. Make sure that each wire is securely connected and that there are no loose wires that could cause a short circuit.
Connect the HDD LED: The HDD LED can be connected to pins 13 and 14 of the front header (LEDH1).
Connect the power LED: The power LED can be connected to pins 3 and 4 of the front header (LEDH1).
Connect the reset switch: The reset switch can be connected to pins 7 and 8 of the front header (LEDH1).
Connect the power switch: The power switch can be connected to pins 10 and 11 of the front header (LEDH1).
Make sure that you connect the wires correctly and securely, as an incorrect connection can cause damage to the motherboard or the front panel components.
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will. Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide. Hopefully this information helps.
2. Just plug the front panel switch headers to the JFP1 main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will. Note:
you cannot have linein connections from the front panel the motherboard usually dont support that.
IF you would like to have two lineins at the same time trty using a stereo splitter and a stereo extension cable.
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
To connect the front panel usb you have to open the cpu cabinet and on the motherboard you will find the usb pins where it will be written Front_USB you have to connect the front panel usb wires to these pins you should see that thier will be a no connection pin at one end which you have to plug carefully
Front Panel Connector
The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins . this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time , but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you bye any doubts you can reply me i am always here to assist you please rate my solution have a nice day
By default, the pins labeled LINE OUT_R/BLINE_OUT_R and the pins LINE OUT_L/BLINE_OUT_L are shortened with jumper caps. You should remove the caps ONLY when you are connecting the front audio cable. So, if you are going to use the back panel, you should short the pins mentioned earlier. You cannot use the back panel and the front panel at the same time. If you want to use your headphones using the back panel, short the mentioned pins and connect your headphones to the green header of your back panel audio. If you want to use the front panel, take off the jumper caps and connect the front panel cable. Remember, if you connect the front panel audio cable, you won't be able to use the back panel. If you are going to use the back panel, don't forget to return the jumper caps. Usually the 5-6 and 9-10 pins. Hope this helps.
