I have a router which seems to work, but I can only occasionally connect to it by cat5 cable. I can ping it every now and then, when it first starts. I would like to know how to reset it back to the factory settings.
SOURCE: Netgear DGN 2000 won't connect to internet by cable / wifi works
I think the DHCP server on the router is not working properly and that is why your wired compuetr is not getting the IP address from the router.
The best option to resolve the problem is assign a static IP address on the wired computer.
First check the IP address of the router,
For example , the IP address of the router is 192.168.1.1, then assign a static IP on the computer in the range of the router IP address for example 192.168.1.10.
For WIN XP
START ==> Control panel => network connection => local area connection - right click on local area connection and go to properties ==> select the option Internet Protocol TCP/IP and click on properties button. Now you will the option obtain IP address automatically.
Change it to use the following IP address . Here you can assign a static IP.
Click Here for more info about networking
SOURCE: I cannot get my comcast supplied modem to
Hi, Follow the steps below to reset and configure the router:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
SOURCE: Netgear router - wireless transmission not working
Try this link, you must turn on wireless to start it.
Have a great day.
SOURCE: Can't connect to some websites with wireless router connected.
access your router with folowng link
http://192.168.1.1
or http://192.168.0.1
then type useranme and password as"admin"
or pasword is blank
then check in filter there id blocking of some sites.disable it.then save settigns and restart router.
SOURCE: my netgear rangemax does not emit a steady wifi
Intermittent wireless connection can be caused by different factors, such as:
1. Wireless interference within the network. For best results, place your router:
- near the center of the area in which your computers will operate.
- in an elevated location such as a high shelf where the wirelessly connected computers have line-of-sight access (even if through walls).
- away from sources of interference, such as microwaves, and 2.4 GHz cordless phones.
- away from large metal surfaces.
2. Wireless settings on the router are still set to default. This may cause conflict with other Netgear routers within your network range.
- change the router's SSID or wireless network name.
- change the router's channel.
- enable wireless security on the router.
3. If the wireless connection is still unstable after performing the steps above, it is possible that the firmware is corrupted. Upgrade the router's firmware.
