Question about Hobart Welding Tools
I have a hobart handler 150, i have it run through a 50 amp plugg in and breaker dont know if thats right because it wont weld the wire burns up to fast what should i do?
None
    New Friend:
  • 17 Answers
Try increasing the feed rate. Decrease voltage also. If still no luck, try checking the wire diameter. If you are using flux core wire, make sure the wire isn't too old and it hasn't been exposed to moisture. If you are using gas, make sure that the gas regulator is working properly. If so, then try getting closer to your work with the nozzle. Distance from your workpiece and wind can interrupt the gas shield, causing the wire to burn unshielded.
Posted on Mar 23, 2012
6ya staff
SOURCE:
luxur4
Ron Jones
  • 92 Answers
SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Posted on Feb 20, 2009
shane covert
  • 225 Answers
SOURCE: I have a hobart handler 140. wire feeds ,no weld
check main contactor or diode bank.
Posted on Jul 03, 2009
Anonymous
SOURCE: I have a Hobart 135 Handler wire feed welder that
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
Posted on Aug 20, 2009
ampman
Mike Ryan
  • 98 Answers
SOURCE: Hobart Handler 175 230 Volt Mig trigger
also do you hear any clicking when you depress the trigger?
You should. If nottry to jump the trigger wires inside themachine right where it goes out to the "gun"wires? worksnow? problemis in the gun cord somewhere.
Still not working? CHeck the contactor. SOmetimes a boxelder bug will get inthem and prevent them from working, or the contacts fry themselves.
Posted on Oct 01, 2009
oneStan
oneStan
  • 434 Answers
SOURCE: I have a hobart handler 120/90amp wire feed welder
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Posted on Feb 02, 2010
New Hobart Handler 140, feeds wire properly, but no weld output
Check the two main diodes. These units have a light duty cycle. About 20% if I remember correctly. I have one that I was welding with for a considerable amount of time, and burned up the diodes. You can test them by disconnecting the wires (with unit disconnected) and use a ohm meter. You should get a reading in one direction, but not the other. If no reading, then the diode is blown. You can order new ones from your local welding shop. Also check all conections on the secondary for any signs of overheating and loose connections.
Dec 20, 2010 | Hobart Handler 140 Mig Welder
Ive got a handler 135 110v - the weld penetration is very poor - using 030 solid wire with 75/25 gas, I have to run the machine at setting 4 to get a half way decent penetration on exhaust tubing, sheet...
This machine is supposed to be hooked up to a 20 amp breaker all alone, with nothing else running off that 20 amp breaker. Also are you using an extension cord? It is usually not recommended to do so, although I have the same machine and it seems to do just fine. Just make sure you are getting proper power to the machine.
Nov 11, 2010 | Hobart Handler 140 Mig Welder
I have a Hobart handler 120/90amp wire feed welder.When i try to weld,all i get is a small spark.I turn it off,turn it on and it does it again.The wire feed works good,it just sparks,but will not keep...
Feb 01, 2010 | Hobart Welding Tools
Curcit breaker triping
chances being this welder is probaby 30 amp. rated and you probably have amp. service at a lower rating change your breakers to 30 amp. or higher or you fuses i do hope this will help you,thank you.
Dec 23, 2009 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Hobart handler 140 wire feeds properly, will not weld
If it is new i would not play around with the welder Just take it back to where you bought it get them to replace it under warranty
Jun 10, 2009 | Hobart Handler 140 Mig Welder
Wont spark or weld
lets go over the basics 1 do you have it set up ,the wire feader turned up at least to see if it sparks 2 do you have itset up at least to see if the amps are on enough to get a spark? try thoughs and see where you are,then turn those up enough to weld with . (make sure your wearing a good helmut .please you only get one pair of eyes!!!!!!!!! )hope this helps jojogunn.
Mar 13, 2009 | Hobart Handler 125 Ez
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Welding Tools Logo
218 people viewed this question
Top Hobart Welding Tools Experts
David Soto
David Soto
rjivaro
Bryan Epland
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
