Computers & Internet Logo
Posted on Nov 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stack of computer hp pavilion 1430 just keeps blinking cannot turn on or off
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 114 Answers
  • Posted on Nov 05, 2008
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
114
Questions
0
Helped
48186
Points
208
Can you explain what you mean by "stack"? Is this an external RAID array? Is this a software error message you are getting on screen? If on the other hand you are referring to the box that everything else plugs in to that would be the computer, everything attached to it, including the monitor is a peripheral. If it's the computer that has a blinking light on it and won't turn on or off, it must be on for there to be a blinking light... to turn a computer off manually you need to hold down the power button for over 4 seconds to forcibly turn it off.
Disconnect all external devices such as printers, scanners etc. etc. and try turning it on again, if you get the same problem disconnect absolutely everything including the power cable and hold down the power button for 30 seconds (time it as it will seem to take forever) and try again.
Message back if it's not the computer, just a peripheral your having problems with or if you still get the same problem.
  • Anonymous Nov 05, 2008
    Going by the rating you still need some help with this problem? Can you tell me what happened when you tried the diagnostics for a computer problem I gave you? Or if it's not the computer your having a problem with but an external device can you give any more information as to what it is other than "stack" since stack is not a specific device or component and could refer to any number of devices?
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
I have a HP Pavilion dv8225nr notebook pc and when I plug the ac adapter into the notebook the battery light keeps blinking and it wont hold a charge. When I keep it plugged in and I turn it on it wont...
It is most likely a bad AC adapter. One way to test it is to remove your battery (I put the steps to do this below) and just plug the laptop in with the battery removed. If it does not power up then your AC adapter is bad. You can buy new batteries online or at your local electronics store. I would advise against buying them from a store though because they are usually much more expensive. I did a quick google search and found some on amazon for a pretty good price.
http://www.amazon.com/HP-Pavilion-DV8225NR-Battery-Replacement/dp/B003KVZIQ2
Remove the battery by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch to the left.
(The front edge of the battery disengages from
the computer.)
c. Lift the front edge of the battery up and swing it back.
d. Remove the battery.
MY HP DESKTOP COMPUTER HAS A BLACK SCREEN ONLY A BLINKING LINE ON THE TOP LEFT SIDE AND THE CPU WILL TURN ON NORMALLY ALL LIGHTS EXECPT THE SCREEN PLEASE HELP
Taht means not your computer is not booting up to windows, try to boot to safe mode, turn off the computer then turn it back on then keep on tapping F8, then choose safemode.. once youre able to safemode, do system restore going back to the time its properly working... If nothing happens, you will need to reinstall the operating system using the recovery disc that came with the computer.
Hope this will help... Please rate....
My HP pavilion monitor keeps blinking & can't access???
be sure that the problem related to the monitor and then if you r technician you should check the power supply board and inverter it can be a problem of lose chimic capacitor be careful its dangrerous
How to replace lcd panel for hp dv4 1430
If you have to ask "how", I strongly recommend that you STOP, and instead take the HP to an authorized HP Repair Depot, and get the repair done correctly, quickly, safely, and efficiently, at no "risk" (one mistake, and you turn your laptop into a $500 "paper-weight" or "door-stop").
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
3helpful
2answers
I have an hp pavilion dv4- 1430 us that won't turn on
I had the same problem with my hp pavilion dv4 1430 and to fix it I just took out the battery and unplugged it from the power adapter and pushed the power button and waited for a few minutes I put it all back together and started it up and the screen turns right back on.
1helpful
HP pavilion ze2000 laptop doesnt turn on
Hi there.
Take the system memory out and clean the brass contacts, then reseat the memory and try to boot the PC up again.
The memory is located behind a panel underneath the laptop like this >>>>>> e1bc638.jpeg.
Good luck and thanks for using FixYa!!
HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Won't turn on
Open your cabinet,
Make sure that your computer is swithched off completely.
Remove your RAM,
Rub it with an eraser (on the connections),
Plug it back,
Swicth on.
Please rate.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
