SOURCE: Microwave turntable won't stop running
This is usually caused by either a bad door switch, but may instead be a loose door switch mount or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: Ummmm I feel stupid
The manual is on the Emerson site at:
http://www.emersonradio.com/owners/MWO%20manual/MW8115SS.PDF
But it doesn't seem to mention a way for you to change the lamp.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: Emerson microwave oven model number MW8115SS
You don't state how old your oven is, or if you tried other food items afterwords. I also assume you inspected for foreign metal objects in the oven? If it does this whenever you attempt to cook in it, then it sounds as if your oven may have a wave guide cover malfunction or burned area.This part can be replaced by the consumer in most cases, but only after consulting with a trained technician or your parts supplier.
SOURCE: How to stop the beeper and reset the "code' light on panel?
You have a shorted 2 pad on the keypad.
Since
it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
