Televison & Video Logo
Anonymous Posted on Mar 19, 2012
Set won't turn on, 10 red flashing lights
Won't turn on, 10 red flashes, pause, 10 red flashes
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Mar 19, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718636
Points
48227
This is an error code and depending on brand/model number can have a number of meanings---
You can GOOGLE the model number with "error codes" etc to get an idea of what likely your error code means.
5 Related Answers
Anonymous
  • 90 Answers
  • Posted on Mar 03, 2009
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
electroman
  • 1039 Answers
  • Posted on Apr 25, 2009
SOURCE: 13 red flashing standby lights tv turns on, then off
Seek professional serv technician. No listing for 13 fashes only up to 9.
Anonymous
  • 197 Answers
  • Posted on Jun 07, 2009
SOURCE: Yesterday morning my son turned on our Panasonic TH42PZ80U and it would not turn on--a little red light nest to the on button flashes red tens times, pauses then flashes ten times again--
bad main call panasonic
Anonymous
  • 58 Answers
  • Posted on Jun 16, 2009
SOURCE: Panasonic Plasma HDTV 50
Please make sure your connectors are in the proper place.
The HDMI inputs on the rear of the TV are optimized for use with Audio/Video devices, Blu-ray Disc Player, DVD Recorder, etc.
The front or side HDMI inputs only are designated for PC. To use the TV as a PC monitor, advise customers to use only front or side HDMI inputs.
Anonymous
  • Posted on Jun 24, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
The red standby light flashes in the code of 4 times then pauses then 4 times then pauses.
Over voltage protection function is turned ON. Just unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so and check. If it do not help you, the main power regulator board should be checked and replaced. If you wish to get more details about blinking codes to Sony brand TVs, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Mosaic /Timeslide option.
TV Won't turn on, Has flashing red light.
Flashes of standby light is fault indication. Count it and confirm the number of flashes occurs at one time switch ON. If you wish to get more details about these blinking codes to Toshiba sets, check this link. Pull up older posts there.
Speen Queen washer won't start
Count the number flash,s before a pause.
This is the error code
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
50 inch Panisonic TH-50PZ85U, wont turn on and has red light flashing 10 times
thats usually caused by a blown thermal fuse on the transformer and the 10 blinks appears. I can assist but will need to do it via email you can contact me at [email protected]
1helpful
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 • Cell Phones
1helpful
3answers
The red standby light is flashing twice with a pause, then twice and a pause etc. There's no picture or sound and the light flashed whether we have the tv on or off. Any suggestions?
This blinking is a diagnostic code. Please update this with the model number. These sets contain circuitry that will shut the set down and display a code like this when a problem is detected. With the model number, I can look up the problem and provide potential repair suggestions.
Thanks,
Dan
3answers
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
2answers
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
