Question about Onkyo TX-SR806 Receiver
Onkyo sr806 makes extreme static noise thru speakers until it warm up. Takes about 15 miniutes for it to go away slowly
Works fine once the static goes away.
6ya staff
SOURCE:
Anonymous
  • 14 Answers
SOURCE: Onkyo TX-SR806 7.1 Channels Receiver
If you have disconnected all connections from the receiver including your sources and the unit shuts down and goes in protect then there is an internal shortcircuit on the receiver and you would need to send that to an authorized service center. Now, since you just bought it 4 days ago, if you purchased it from an authorized dealer of Onkyo you could have it replaced since its way within the 30 day return policy. But, if you have purchased it from circuit city, unfortunately your option would only be the service center for repairs. If you send it to an authorized service center, you would need to put in a copy of your sales receipt together with a brief description of the issue you are encountering. Where did you purchase your 806?
Posted on Mar 03, 2009
Anonymous
  • 14 Answers
SOURCE: Dish Code for TX-SR806
Dish Network
System
00775, 01505,
01775
Anonymous
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Posted on Apr 19, 2009
Anonymous
  • 5 Answers
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
Posted on Feb 12, 2010
Anonymous
  • 7 Answers
SOURCE: I have a Onkyo TX-SR806 HDMI output does not work
Sounds like you may have a bad HDMI card my friend. I had an issue with my HDMI card that was causing blue dots to appear on the dark parts of the screen, when outputting 1080p over HDMI. This is a rather common issue, so it wouldn't surprise me if your HDMI board needs replacement - especially if you've ever experienced the infamous blue dot issue.
Posted on Mar 04, 2010
What is causing failure?
The power supply will keep up this frustrating routine until it finally goes completely dead.
Apr 07, 2016 | Televison & Video
Eclipse avn 5435 deck plays fine but once in a blue moon no sound comes from it. Only using rca on unit, gps works fine. I unplug all connectors and then works fine.
Jess, do a wiggle test on cables when you have volume, wiggle wires one at a time to see if sound goes out or static.
press the helpful button
Feb 07, 2016 | RCA Car Audio & Video
The digital audio out to my a/v receiver is fine for about 2 hours & then I get loud static.Is it the tv or the receiver?
If you have another source for the AV receiver like a DVD or blue ray player then switch to it and see if the static goes away. If it does then it's the TV.
Oct 01, 2013 | Sony Bravia KDL-40S4100 40 in. LCD TV
AM Radio Static
You have a defective antanna or a defective antenna ground.
Jun 13, 2012 | 2000 Ford Ranger SuperCab
Speaker sounds very staticy
This is normally due to a bad connection, however it can also be caused by a blown speaker. replace with another speaker to see if the static is still there, if you still hear the static then the speaker is fine and the wire is broken somewhere, is the sound of static goes away then problem solved.
Apr 04, 2010 | 2003 Mitsubishi Eclipse Spyder
The radio in my 2003 Cadillac CTS goes to static after after minu
Something to do with the reception or antena system..
Or the tuner in the radio is failing..
Rate well ;o)
Jul 22, 2009 | 2003 Cadillac CTS
PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
May 14, 2009 | Sony PlayStation® 3 (80GB) Console
Cd player works but fades out time to time
U HAVE TO SEE ME I KNOW WHAT U STAEREO HAVE...323 254 3454
Feb 17, 2008 | Jensen CD4610 CD Player
Onkyo TX-SR806 Receiver Logo
355 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
